Sets interval, threshold (maximum number of link down events), and disable time to defaults for link-flap detection.
| ports | Physical ports. |
| port_list | List of ports to set link-flap detection characteristics back to defaults upon. |
| all | Sets link-flap detection characteristics to defaults on all ports in the system. |
| link-flap-detection | Specifies link-flap detection. |
| interval | Resets the time interval for collecting link-flap events to the default of 5 seconds. |
| threshold | Resets the number of link-flap events tolerated before action is taken to the default of 10. |
| disable-time | Resets the time period a port remains disabled after excessive link flapping to the default of 300 seconds. |
N/A
The following example resets the link-flap detection interval and threshold to their defaults on ports 1–4.
unconfigure ports 1-4 link-flap-detection interval threshold
This command was first available in ExtremeXOS 22.1.
